Do the newer 6N clocks fit straight into an older 6N?
Do the newer 6N clocks fit straight into an older 6N? and do you have to take steering wheel off to get them in and out?
  • Views 1.4k
What do you mean newer style, the one with the intruments in the middle and not at the bottom if so its...
2 screws holding the surround, then 1 screw each side to take off clocks.
ye thats right do they just plug straight in like the old 1's and work without any mods?
yep :)
that will be a no! the connector plugs are totally different, i know this because i have the newer clocks an my friend is putting the older shape clocks his mk1, he wanted to look at mine for referance and plugs are completely different
Correct me if I'm wrong, but without the connector plugs be different between a mk1 & a mk4 polo?
late spec mk4 clocks will not fit in older mk4's
