Door card removal and other trim bits 6N
Am considering painting some of my trim bits in my polo 6n, the door cards dont seem to wanna come off like the ones i took out of a 205 did? any advice? also, the trim bits around the heater controls/radio etc, is it just clipped in? cheers.
  • Replies 8
  • Views 3.7k
door cards are held on by two screws under the door handle trim and clips all aound the bottom/sides. twist off the door pin and should slide out from under the window seal.
As richoco said to remove the door card as for the plastic surround in the dash you have to remove the air vents as there are two screws under there , then pull the heater control knobs of the remove the facia cover ( the bit where the lights shine though ) and there are 2 screws behind there that hold it in place as well . then just remove all the switchs , hazards switch , heated rear screen etc and it should come out bud . hope that helps .
Unscrew the door pin then pull off the outer handle with a screw driver then, unscrew the screws then unpop the right and left sides. Then you need to move the door handle top open position then just pull it off.
Hope this helps :-D
door pin? as in the bit you pull on the inside to lock/open the door, yeah? haha
and also, outter door handles, theres a screw on the inside of the door, which i would say is holding the handle on, is it hard to remove them and link it all back up properly? - respraying my car but dunno wehther itll be better removing them or masking them, cheers
Yeah thats the door pin mate haha.
Not tried that actually but i can have a gander in the haynes manual tomorrow morning for you then post it up here if its easy or not (would do it now but i cant be arsed to go out to the car and get it lol)
To remove the door handle, undo that torx screw that on the inside of the door and slide the handle forward.
That's it, it should come of.
gonna have a dabble at this tomorrow, if i slide the handle forward, will it come off a rod or something? does it go back on easily enough? cheers
Also, removing the rear bench, whats involved in this? i really need a haynes manual haha. thanks
To remove the rear bench, pull it forward and upwards, it should pop up, after that, under the fron of the bench there's like a thick black wire holding it in, push them inwards towards each other and the rear should come out.
