Northampton
Hi guys i have lowed my polo 6n and I'm trying to find out if i would really need to do the camber or can i get away with it, i have lowed the car 100mm what do you people think? I'm from Northampton and if i need it done dose any one no what garage's do it and how much?
any help would be good. :-)
Many Thanks
Rob
  • Views 990
Many Thanks
Rob
I'm having the same problem.. lowered mine bout 70mm all round, looking like i gotta get camber setup.. dont think it comes cheap tho :( ahhg!
I got told i was looking at £90, i was hoping that it would be about £50 as i would like to spend that money on sorting the car for the shows that are coming up
Undo the two bolts at the bottom of the strut, pull the hub towards you while tightening the bolts back up again. Cambers all done! Simple!
Still need the tracking doing though.
give bodymek at st james a ring I'm pretty sure they will do it not sure for how much tho
Would of thought Northampton Motorsport would be the most knowledgable with this.
Theyll do everything for you and you know its done to good standard. I got F1 Autocentre to sort mine out and I'm sure they haven't balanced my wheels up. 60mph the wheel starts to vibrate.
