Mk1-3 coilovers with no strut exchange!
in stock yet? or chance of being before the end of the month
  • Replies 158
  • Views 47.7k
Yeah should be back in now, will check.
great I'm going to take the plunge i will take some photos of install aswell if you would like them
are these still available, buying a mk2 saloon at the end of the month
Yep in stock and available, now with the shorter springs.
payment sent phil :)
what does shorter springs do ... What's the ride height options with them :o
Just means they will go lower without having to remove the helper springs. Should see 110/20mm ish with the helpers in.
:o... I'll be ordering mine within the next week
I need to save the money for these, still £360 for just the fronts?
Yep
defo getting some after xmas for my mk3 1.0 litre coupe
how much all four corners ?
Payment sent Phil ... Cheers for you are time
£480 delivered.
Got these on my G40 and thoroughly recommend them! Had them on for about 8 months now and they are performing well :) great range of adjustability (Better than any spring/shock kit!) and the ride is decent :) plus phills the cheapest you'll find!
Oh by the way phill, do you by any chance know the Diameter of the coilover struts?
Edited by mrtom22
Cheers Tom, glad you are happy. Which part do you want the diameter of exactly? Send me a PM...
How long do these take to come through post ...cant wait to get them
Hi, are these shortened at all the strut I mean not the inserts?
Strut is shortened yeah
Ok sweet, do you use the existing insert nut when they have been shortened and could I buy just the insert? And modify my strut to suit?
No, modified nut, and inserts aren't available separately, can do the Gaz adjustables for about £220 a pair.
Alright pal, are these in stock ?? And how much is postage to manchester, real intereseted in a piar, could you pm with reply, just so it pops up in my email, so I know when to reply, cheers
Had mine come through on Thursday, Going to press the bearings in this moring and fit them this afternoon
are get some pictures up when I'm done. Thanks again Phil
still £480 all round?
Indeed they are.
