Mk1-3 coilovers with no strut exchange!
Are these in stock at the moment?
  • Replies 158
  • Views 47.7k
Yeah back in now.
What is the delivery times on these and apart from bearings will i need any other parts to fit them
About a week
sweet deciding wether i want these or your 80/60 kit not sure i want to spend 5 times the money on my suspension than what i bought the car haha, are the delivery times the same for the other kits
Depends on what you'll be doing with the car really. Both about a week.
  • 3 months later...
from the pics i see everyone is sticking these on mk3, will they fit my 79 mk1?
Yeah will fit the mk1 fine.
Got any fronts available?
They will fit but you need mk3 tca's as the spline on the ball joint is a smaller diameter on the mk1s
Edited by MoustacheG40
Are the shocks and body insert shorter than the standerd bodys ?
I'm sat about 85ish atm on springs and shocks and its preety much on bumpstops ..
Would the coilovers allow for more travel ?
Yeah, the whole body has been shortened, lowering the steering arm as well.
sweet .. There not normall size fk shocks inside then i take it ?
No...
Haha sorry for stupidity.. just looked back at what i said lmao
What make are these then, I've seen a set on the net TA's there like 470, Whats the diff?
hi have you got any in stock alos would need to get a chassis notch if i were to lower it the full 100mm becuse at the moment I'm lowerd 80/60 and my drive shafts seat quited low ?
thanks
In stock, depends on all sorts, but should hit 100mm without a notch.
so what will i need to do with the new front coilies before bolting thm on, is it just bearings and the bashing the hub on? anyone got a guide? also does anything get in the way of lowering? i.e 100mm plus down? think i might order some fronts soon how would i go about this?
Fit your old hubs with new wheel bearings. Will go as low as your chassis can handle, if you want to order just give me a PM.
hey dude would you be able to sell a set of shortened dampers on their own?
Unfortunately only the Gaz.
Are gaz shorter? Got a price?
Oh my bad.
I wanna shorten my struts like the coilovers he sells, but need dampers.
90mm isnt enough! :lol:
