Mk1-3 coilovers with no strut exchange!
Phil
I'm am looking for some front Coil overs for my mk3 polo 'M' reg do you have any at a good price
If so could you please give me a call on thanks Callum
  • Replies 158
  • Views 47.7k
Phil I have an early mk1. Do I need later mk1 balljoints to fit these?
How will these work for trackday use?
They'd work fine but they are designed for road use really. Depending on how serious you are with your track work, ideally you would be better off with custom valved dampers and stiffer spring rate.
How much posted for just the fronts?
are these height adjustable ?
£340 for just the fronts
Height adjustable front and rear.
Hi have tried sending you a pm but it keeps failing. Would you be able to supply coilovers for a Passat B2 as they share the same front strut design as I'm aware. would just need higher rated springs to take the weight of the 5 pot
Have sent you a message, and cleared out my inbox. As far as I know, the B2 passat uses early Audi 80 struts, could be wrong...
