mk4 1.4 16v 3dr breaking
Breaking mk4 16v 3 door, body parts are all metaic black, all parts available, I also have a GTi engine with ancileries for sale, red mk4 bonnett, AFH engine internals
Matt
Edited by Pc
  • Replies 74
  • Views 2.9k
Please can i have prices on each of the following:
-standard front grill
-grill surround (if its the plastic one)
-drivers side mirror cap
-front bumper
-front splitter
-cover for the fuses on top of the battery
also would you post, if so how much :)
rob c:
standard grille and battery fuse cover- £10
i have the metal grille surround - £5
dont have the metalic black mirror but have other coulours - £15
front bumper with all grilles and splitter - £45
yes i can post for around £20
Matt
have you got the fog ligts
Hi,
I have a complete fog light set with lamps, loom, grilles and dash switch whole lot £70
Matt
has this got the new style clocks in it?? I'm looking for the clocks and the interior wiring loom from behind the dash
whats the rubber like around the sunroof mate? And price on the the rear drums/hubs+bearings? Front bottom centre grille? Cheers
seanvw:
it has the old style clocks in it, sorry mate
danny6n:
i will have alook on the weekend at the sunroof, i've sold the rear axle and front bumper.
Matt
details on both engines, mileage, service history, condition, ancilliaries etc
PRICES!
Wheels?
hello mate i`m also intrested in the gti engine couls i have some history on it if you have any also what ancileries do you have for it? also do you the loom and ecu etc?
how much???
cheers dan
Pm'd
Mate, ill take the rear lights. How much all posted? cheers Matt
Edited by Mattnaz
grungeisdead, AFH engine, gearbox, subframe, ECU, entire car loom with central locking, gear selector, driveshafts, hubs, brakes, master cylinder etc, basiclay the whole front of the car but no rad. the cars origioanl engine snapped the cam belt, so i bought another engine off a mate with 68K milage, i have changed the cambelt, head gasket and headbolts looking for £260 engine conversion or £320 for the whole lot. i can send on a pallet if needed.
GTi engine came from a 65k milage GTi that was being broken for spares, I got it to do a 1.6 AFH GTi conversion, engine comes with: exhaust & inlet with TB manifold, flywheel and clutch, part of the engine loom with coil pack and leads, air con pump, alternator, pwr steering pump, GTi engine mounts, thermostat and pipes, starter motor. may be a few other little things. £220 can send on a pallet if needed
majic79, wheels have been sold
polodan2009, see above description
Mattnaz, £40 delivered to mansfield
can post all the above or collect from Braintree or Hatfield
Matt
hey, did u have electric windows? if so how much for both window regulators, posted pls :)
Do you have that black plastic, where the rear wiper goes. If so how much posted please.
SamyKate, i will check they still work ok when i am home next weekend.
DubSingh-Dhali, i have the black plastic for the wiper (not a blank if thats what you are after),
Matt
No I'm not after a blank mate just the original one with the hole in it. How much do you want posted please?
You got any clear side repeaters mate? If so how much for them posted?
Craig
DubSingh-Dhali, £1.50 posted, i will post monday week when i am home
CraigH17, clear side repeaters have gone.
Matt
Edited by Pc
Matt
Yeah thats fine. Pming you now.
Payment sent. Thanks
No problem mate
is the power steering hose/pipe available?
it's the pipe that goes from the pump across the front valence up near the battery tray then down towards the bulkhead and back along to the rack.
I'm in colchester and work in chelmsford, if you have it in good cond. and it's for sale please give us a call on 07983460690 cheers john
how much for the complete powersteering.
rack
pump
pipes etc, can collect I'm not far from you.
thanks
