door pin mod on a 6n2
hey guys, i saw somewhere someone had done a little door pin mod so that when you lock the car the door pins sit flush, to do this is it just a case of chopping down the metal part that the pin screws onto?? i dont wna do it n then i mess it up, help would be apreciated :)
  • Replies 13
  • Views 2k
you need 6n2 door pins and surrounds
hey dude i have done this you dont need surrounds
all i done was unscrewed the actual pin (the plastic bit)
then chopped the metal bit about 4mm down now it sits flush ..... can take a picture if you want?
also dont do this if you dont have central locking (which i dont :sad: )
hope this is helpful
I've got a 6n2 so i have these allready, its ok tho i found the place i found the picks of it and think I've gotta chop the metal thread down! ill give it a go
Hi, you need to chop the metal, then glue the pin back on, because obviously you will have cut the thread off of the metal rod meaning the pin can no longer screw in as normal.
Personally this isn't a mod I'd do incase the electrics failed and you were locked in lol!
i chopped the thread off cos i go for the more do it now think about the consiquences after its done lol
LOL that's how I usually am, but I don't have enough trust in my remote central locking even though it's the best you can buy!
cool thanks for all you are quick replies.
so indy do i need to cut all of the threaded part off the metal to get it to sit low enough?? I'm sure it will be fine if i get locked in ill have to smash my own window i guess lol
i have central locking and a unlock/lock button in the car too :)
No no not neccessarily all the threaded part. Just the correct length to get it sitting flush. But either way because your cutting into the thread you'll need to glue the pins back in place.
Just lock the doors, measure how much the pin sticks out, and then cut that amount off of the metal rod.
Same I have a lock button etc in the car, but the Toad alarm overrides this and automatically locks the car 10seconds after the engines started!
damn that sucks... what engine do you have in your 6n2? was your toad alarm expensive to get fitted?
ah ok then, I'm sure ill manage to do this then!
thats kool that u have that button too i thought only gti's came with it? u can get the normal alarm to do an auto lock on the doors aparently and then if u break hard it should automatically unlock but i didnt like the sound of it.
Nope it's all cars with central locking.
Just a 1.4 8v.
Alarm was £272 fitted at my house and I had a few upgrades which I requested.
dont have to cut the thread, i took the whole locking rod out and cut and bent thebottom leaving all the thread un touched!
