Help with clocks...
  • Views 877
wouldn't imagine so, you are clocks am mk4 need the others are mk5, different shape n clips are different, hope this helps :-)
Na sorry they will not fit as you have 1 of the early MK4 which come in the 1st link, But from R reg they come with the newer style like the 1's in the 2nd link its still the same car ie MK4 polo but vw updated the clocks,
And you cant fit the newer 1s to the older 1s as the older 1s are more square and the new 1s are more rounded and they will not fit in the hole in the dash
Edited by Po*Low*
ok thankyou :)
