Looking After Your Bonnet Bra
( Hopefully This Topic Will Be Usefull For Other People To Also Find Out How They Look After Their Bonnet Bras )
Just Need To Know If There Is Anything You Need To Do To Look After A Bonnet Bra .
- Does It Matter If It Gets Wet ?
- Does It Matter If You Leave It In The Sun ?
Any Other Tips Would Be Appreciated .
Thanks In Advance ,
Pete
  • Replies 8
  • Views 1.5k
It isn't the bra you should be worried about it's the paint underneath it.
The bra is pretty much bullet proof, however the paint under it isn't!
Don't leave the bra on too long. Your paint needs to breathe and you don't want to trap water inside it either because the bonnet will begin to rust if there's any exposed chips.
Also, when using the bra always apply detailing tape first on the bonnet. This is because grit is often trapped in the bra, so when you fit it onto the bonnet the grit and little stones will be rubbing on your bonnet causing more damage!
That's about all there is to know!
seem to cause more trouble than preventing it. They do look the dogs danging dick though.
By all means they do prevent problems but you have to use them properly.
Dont leave them on in the snow!! Hahaha!! Messes them up a little!! I had mine on for about a year none stop, took it off now and again for a clean and breathe and never had any poblems :)
Ok , Thanks For The Reply . Hope This Helps Out Anyone Else That Was Wondering About Looking After Their Bonnet Bra .
Pete .
I ran my bra for about a month and a half, apart from the line of dirt where the bra had been placed I noticed no damage etc. But then my bonnet isn't immaculate, if it was, then maybe i'd of noticed any damage. If you're serious about your paint, make sure you protect it before putting the bra on like Indy said :)
what do you do with the detailing tape? where do you put it?
cheers
i dcont know much about bonnets, but i'd guess at taping up the bit of your bonnet, covered by the bonnet bra, to prevent grit scratching the paintwork for when your not using it, if that makes sense?
