handbrake stopped working? how do i tighten it?
hi peeps.
tonight my handbrake decided to make a loud noise then goo really slack. its only works a tiny bit when my handbrakes up as far as it will go, so this means it isnt snapped right?.
but anyways before i have an attempt my self any tips on how to check it and have a go at tightening it up?
cheers, jack
  • Views 1k
If it's made a loud noise I'd get on your back and take a peep underneath. The handbrake splits into two cables. One for each rear caliper. Take a look at both sides. One may have snapped. Pretty cheap to replace. The ones one a 6n2 are adjusted by two nuts under the handbrake plastic console in the centre of the car to the rear of the handbrake (iirc)
ok cheers mate (Y) :-o
Ye I'd say one side has snapped, this has happened on a few cars of mine not just vws. Easy enough fix and cheap, even if done by a garage.
