leaking loon
as title states my 92 loon is leaking water in the boot coming from the strut tops down and leaving puddles in the boot and i have no idea were its origonating from does anyone have or had this problem its really annoying as my boot floor is rusting now and id love to know why it come in at both sides as well not as bad though on the passenger side
any help is greatly welcomed as I'm stuck for ideas other than leave a towel on the boot floor
  • Views 885
Hi there i had similar prob try checking under the rubber seal. There two thin parts of steel one on the nearside and on the offside nearest to the rear screen, you will probably find they are corroded if so just a bit of silicone seems to do the job
bottom corners of rear screen
i have a small hole in the bottom corner of the rear screen frame i take it this is were the problem is then how hard is it to remove the rear screen
