De-rear wipering
hard task? and also does it make much difference in the rain/it wont wail a MOT?
  • Views 1.2k
easiest job ever.. remove wiper arm... remove inner covers inside tailgate.. remove motor.. find a gromet "biggest job!" bobs your uncle.. and with the mot if its not there they cant fail it :D
i did it today, just got a rubber gromet from B&Q, 10 for £1.50. i got 25mm and fits perfect. :D
good timing I'm doing mine tom! do you thinck 25mm will be ok for 6n2? and what section was the gromit in b&q lol
well it fit into a mk7 polo and a mk5 golf, I'm guessing there all the same, they only do 25mm and 20mm so even if it wasnt right there only £1.50. it was in the building section, i just asked somebody :)
Dont Forget To Block Off Your Rear Wash Pipe . Just Fold It Over And Cable Tie , Should Be Enough . Dont Want To Make The Inside Of Your Boot Wet By Accident .
Pete
