16v splitter
do they just pull of or are they bolted down??
Screwed on most likely.
2 screws in the far corners where the skid plate type things are. You will see 2 holes, then I think you need an 8mm socket and ratchet iirc.
The rest just unclips.
cheers deviance mate, gnna be a nut and bolt though mate aint it so need socket ratchet and another spanner like x
Nah it's not, 2 self tapping screws that screw into the bumper. If you look at the bottom of the splitter you will see 2 holes, one either side in the corners, stick the socket in there, undo them and pull the splitter off. The splitter clips in pretty damn tight so it will take a good yank.
