anyone ever fitted a sunroof to a non-sunroof model?
was at the scrappy today robbing some parts for my loon and had a look at the sunroof of a mk3 while i was there, doesn't seem to be too tricky to fit one?
didn't have a look under the head lining so not 100% sure what's under there but i can't imagine it being that difficult to be honest
just wondering if anyone on here has done it before? and if anyone knows if the mk2 and mk3 roof profile is the same?
  • Replies 13
  • Views 2k
a glass pop up roof could be done reasonbly easy
the metal sliding one would be major surgery ..
it was the slider i was looking at, i can't seeing it being too tricky, as long as you take plenty of measurements from the donor roof so you got everything lined up ok before cutting the whole, then i should think it's just a case of welding up the outer skin of the roof and working out where it needs strengthening inside? i should think the complicated bit would be making a new headliner that leaves enough room for all the mechanicals? (can you tell i'm no good at interior stuff but don't think twice about taking an angle grinder to a car and welding something else on? :lol: )
might see if i can take a mould of my mates roof so i can see if the mk3 roof profile is the same
Edited by skapunk1
the sliding roof models are double skinned and the headliner drops down about 1" from the normal position.
could be done but you would need the inner skin cut out a donor car.
pop top one would be much easier to do.
would it really need the inner skin though or could i get away with welding some bars in to stretch the roof lining over?
id say you need the inner and outer skins ...or at least cut that part out and weld in
have you actualy looked at one? its not a bare edged hole in the roof skin , the edge of the hole has a lip all the way around that youd never replicate , then once the roof is slid back theres (cant drescribe it ) a tray where the cables and drain tubes go etc
id suggest you go back and have a very good look at one with the roof open and the headliner yanked off...it would be a considerable job for someone thats good at bodywork
or settle for a pop up one that just needs a hole made in the roof
had a good look at it from above with the roof open, but yeah, would need to pull the roof lining off and have a proper look from underneath
pop up one just doesn't do it for me :lol:
easiest way to do it would be to weld a full roof on
What I was going to suggest, just cut the entire roofskin off the donor car and weld it in place of your old one.
Do it Billy Idol styleee
thats the way to do it :) (specially on bams lambo)
I didn't like mine,not enough headroom,kept bashing my head on the roof when settled and couldn't even sit straight in the first few minutes of driving.
Now i have a non-sunroof shell i dont have any headroom issues,its great.
And i agree with the above saying that retro-fitting the factory slider would be a massive job,easier would be jigging the shell and spot-welding a factory roof on.
I would like to fit a full length canvas on,I think they fitted them on 6ns.That is the only one i would consider on my mk3
Mk3s with sunroofs are shit for headroom!
