9n wing mirrors
Hey,
I want to fit some f1 look wing mirrors to my 2002 9n. Has anyone fitted non OEM ones?
The current ones are OEM electric.
How do i go about this, the stock ones have a base plate that they are fitted to. do i need to source/get someone to make some new base plates to attach the new mirrors to + how do i get the old mirrors off?
Really in the dark on this so any points in the right direction would be much appreciated.
mark9n
  • Views 1k
take off the panel inside the door behind the mirror (not the doorcard lol) and there you will see two torx bolts, either t25 or t30 iirc. disconnect the wiring if they are electric first then pull them off carefully.
I'm hoping on fitting new polo ones, not any after market shizzle
Thanks for the reply. How do i take it off, just pull at it? does it slot back in place just by itself.
I always worry about taking panels off incase they don't slot back etc...
the panel will pull off, be careful but dont worry they are nowhere near as bad as the doorcard clips. and yes it will push back into place. once you take the two torx bolts out it should pull off, just move it about and it will be sweet.
Nice one cheers man.
Do any other model base plates fit because the 9n ones have the bottom part coming out that the actual mirror sits on and can swivel in to push the mirrors flat to the window. I have found some f1 mirrors which have the thin attachment rod coming off the mirror onto their own small base plate which then fits into the recess on the base plate on the car which most models have, but my 9n has the bottom part coming out that i mentioned before stopping this...
reading back this is probably impossible to understand... :?
