leather vinyl adhesive spray?
leather vinyl adhesive spray? I've got some leather vinyl so i can do some bits and pieces on my interior, and if it goes ok i may even to the headlining.
Anyone no whats the best adhesive to use as I'm guessing a spray adhesive will be the way to go i will be gluing it to plastic trim at first, then will have a go at headlining.
any help will be good and where i can get it from
cheers
pete
  • Replies 13
  • Views 1.6k
3M or EVO STICK are both good spray adhesives...i've used both without any problems.
cheers mate do you no what they were called as I've had a quick look but there is loads to choose from in the 3m range
thanks
pete
Pop down to halfords, they sell the spray adhesive cans for around 7 quids :)
The best stuff to use by far is Evostick or Trimfix.
Trimfix is the only stuff I've used on mine and it's even what my retrimmer is using. It won't sag in the heat, and it will snap your headlining in half before it peels off!
You can get it off of eBay for about 7 quid a can. You'll need about 2.5 cans to do a headlining and pillars.
cheers guys!
i did have a look for trimfix on ebay indy but couldnt see it, will have another look later
many thanks
pete
The 3M stuff was called SUPER 77 iirc and the EVO STICK one i can't
remember but i got it from B&Q and it came in a red can....
cheers guys!
many thanks
pete
need to look a bit harder mate ;)
eBay item number: 130352778616
cheers guys!
many thanks
pete
lol yep found them and bought them cheers once again i put a space inbetween thats why it didnt work!
You won't be dissappointed! Just try not to get any on yourself.
As your a guy you'll have hair on your arms/hands. I'm telling you now, it's like a slow waxing pain trying to get that shit off once it's on you!
lol i will defo have to be extra carefull then, sounds painfull!!! hoping it will come before the bankholiday weekend so i can have a good day or so on it.
cheers
pete
Come to think of it I'm seeing more and more girls these days with hairy arms.... absolutely rank!
is it any good to put onthe material bit on your door cards??
i can vouch for that! ouch! :crybaby:
