HELP! , wet drivers side carpet
lifted car mats in my polo 1.3 cl coupe 1994 today and its really rather damp underdeath jst behind the plastic foot bit . not wet at the side so i dont think it would be the door seal? and lst time i had it on a ramp it all looked solid underneath :S dunno what to do dont want it going rotten! any help much appreciated cheers guys!
  • Views 875
Most likely the battery tray has rusted through, a very common problem on these!
had battery out today, was wet in there but not rusted through at all, jst the hole in corner where wires go but that drains water to outside the car doesnt it? any other ideas I'm stumped lol.
I had the same problem in mine. If you look up at the battery box from inside the car, behind the steering wheel, you can see if there is any rust. If there is, that's where it's coming from :-( My battery box looked ok from the outside as well.
and mine was the same but like above check it out :)
Go to your doctor and check that you don't have a weak bowel ?
