Car pulls to the left under acceleration
when ever i accelerate the car pulls of to the left fairly badly but when i take foot off the accelerator returns to the right
spent 3 hours on the ramps, all bushes are fine and ball joints etc
so mechanic is going to ring vw to see what they reckon, he thinks it could just be the shoulder bolt,
any one had any trouble like this ?
thanks in advance
  • Replies 13
  • Views 3.3k
torque steer :lol:
has it eva bean in a bad car crash?? what wheels have you got on?
wos it a level road you did it on? is the tracking and camber ok?
Worn shocker, spring, wishbone bush, top mount, odd tyres...blah blah, list is nearly endless!
I second the camber and tracking, also check the tyre pressures.
Simple things that shouldn't be over looked IMO.
cheers guys writing down the list and see what the mechanic says he's a family friend and a vw/audi specialist so hopefully have a diagnosis when it goes back in tomoz
also if it was tracking surly id get wheel shake and alot of vibrations at speed which there isnt just a sharp tug to the left on acceleration
Edited by Krash
it depends what way its out. dose it go round right hand corners betta than left hand corners or the other way around?
how long has it done it for? has it done it since you put those after market wheels on?
wheels have been balanced they were on the car when i bought it and just looked through the paper work and found the invoice for it being done
any chance it could be the toe ?
it cood be the offset on the wheels is rong.
the "toe" is part of the traking. i wood get the tracking and camber checked..
cos if your camber wos off it wood make the car act like that.
i would go for wishbone bushes myself
myn was doing this and my subframe was rotten and the wishbone had pulled out lol scary shit
it cood be eny thing mate
wheels,tyers,stearing rack,bushes,tracking,camber,bad crash damage, track rod ends, strut top mounts,
the list goes on and on.
but wood be best changing the bushes befor doing the camber..
only say wishbone bushes as mine went and it pulled left under acceleration,and braked to the right,but yes it could be anything :-)
sorted new bushes and tracking done 7mm out :|
