best thing to do with rusty arches
I have slight bits of rust on my 2 front arches I want back looking clean and tidy
what would be the best thing to do to get them clean and tidy again?
  • Views 1.4k
lol use your noggin and have a think.
Think I'll remember that next time you ask a stupid question Max
My rear arches looked really bad, so much that I thought I'd new metal welding in.
I decided to grind them back, and see what the real damage was. I used a 40 grit flap wheel attachment for my drill, and sanded it all back.
When you get back to bare metal, hopefully there will be no holes! You'll see clean metal, which will be silver, and the rust, which should be black. You need to grind all this rust out, or it will just come back again.
For this, I used a grinding stone attachment for my drill. Make sure you get it all out. It might take a while, but you'll just end up having to do it all again in a couple of months otherwise.
Once you've gotten rid of the rust, you need to treat the bare metal. I used Vactan, which is a rust converter, just to help with any tiny bits I may have missed. Another good product is POR15 Metal Ready. Use etch primer over the top, then paint your topcoat/lacquer as normal.
I was doing mine this weekend, and went to the Manc meet with it half done. Here's a pic someone got :p You can see the bare metal at the top of the arch. This is where I'd ground all the rust out. The other parts of the arch had all the oxidised (orange) rust removed, and the black stuff was left.
27227_377076367851_645862851_3865881_356
I'll get some better pics up later to better show you what I mean :)
Hope this helps.
Edited by tezmc
Hope this helps.
Hmm might start mine Friday and try and get it all done by Sunday
With the paint wont I have to get them to take a sample from my car rather than me just giving them a code as over 19yrs I'm sure it doesn't look the same as it did back then?
Thanks for the help
Yeah, its best if you can get it made up properly from a sample. If I remember right, you are best using your fuel flap to get the match :)
What colour is your car? A good guide to spraying with rattle cans was posted somewhere on the forum. It's a pdf file. I'll try to dig it out for you.
Calypso green buddy
What type of stuff can I use If my arches need filling?
Well on mine, the pitting wasn't too bad, so the Vactan filled it ok. If it's really bad, just use some body filler like Isopon P38 which you can get from Halfords.
