Did You Know ?
May have been said before but...
Next time you in your Polo try this as it work's on mine and my mates Mk3 golf, So get in your car remove your keys switch your lights on and put the heats on full, as you know the keys are not in so the heats wont work, but while you've got them on full and your lights on then put your full beam on "Flash" and hold it on and the heater's kick in. Try it ?
  • Replies 10
  • Views 1.6k
Did you know that if you take the key out you can send live to your headunit but pushing your ignition barrel in :D
Dimz
Dimz
Yer i know that 1
mk3 polos are the same i beleave it wos a way vw checked every thing wos ok
I thought that was gonna be some poor april fools day joke thing for a minute hahaha
On the same kind of note, I found out my new Polo has a function that if you press the flick key lock or unlock you can open or close the windows (a cheap total closer system).
I guess that most people will know this but I though it was a good upgrade from my Fox, as you had to put the key in the lock for it to work.
put lights on pull stalk down and u can open your windows without keys :)
EPIC ill try that
Discoverd this in my old 6n, i thought my electrice were just up the left!!
