water coming in rear paasenger foot well 51 plate 5 tdi
Hi, :-(
wonder if anybody has had the same problem..water gets in rear foot well passenger side, put new appiture seal £80.00 :x , checked the door "shuts" :x ,could it be the water feed to the rear wash wipe? does anybody have diagrams of the wash wipe system. If you do please email me at erniethree@blueyonder.co.uk.
Thanks in advance :-)
  • Views 560
Popular Days
Hi to all,
:-D :-D :-D managed to sort this one out..it was the wash wipe water feed..this had come undone, so every time you wash the rear screen you also "washed" the rear passenger well. It was easy enough to do remove the finishing parts around the well and lower part of door appiture.Remove bench seating..release prongs..easy. Pull back the carpet.As you follow the cables and water feed{thicker black cable} as you get close to or in line the the door catch/shut their is a group of cables bound together in a sponge type foam the feed came loose in their.It is a pull push fit{pretty :x shite :x really}..so pushed it back together and secured it with a tie wrap. Then generally tried to hand dry all the wet areas.
Hope this helps for anybody else 8-)
Cheers ernie
