Photos of 6Ns with lowering springs...
Hey, I'm thinking of buying some Jamex lowering springs from ebay, but not sure what height to go for...anyone got any opinions?
Photos would be appreciated so I can have a look, thank youuuu! :-D
  • Replies 14
  • Views 1.9k
everyone on here will tell you not buy springs and buy coilovers as you are wasting money dude
springs are a quick fix
coilovers FTW!
Didn't want to pay out the money for coilovers...thought springs would be good as they're only £50 compared to hundreds and will do essentially the same thing right?
you can get raceland coilovers for £162 brand new i know its £112 more expensive but your getting shockabsorbers and everything together
Lowering springs maybe a quick fix but if you don't upgrade the dampers, the standard one's will be destroyed pretty quickly, by the time you've saved up for springs and dampers, you may as well keep saving for a month or two longer and get coilovers
save up for coilovers
just a spring kit will mess the handing up and wear the dampers out pretty sharpish
i had a set of springs on my old car it was mad bouncy ended up putting the standards back on
coilovers are the only way, unless you can afford bags
Ok, I'm better off taking advice from you lot about it...you know more than me. Might save up for something like those raceland ones, I'll have a look.
So with coilovers can you adjust the height any time you want?
How much would it cost to get a set fitted at a local garage?
Cheers,
Probably about £100 to get fitted but mk4 polo's are piss easy to do, best off doing it yourself then get the tracking done
Ok, I'll have a look...how much do second hand coilovers usually go for on here?
http://www.clubpolo.co.uk/forum/index.php?showtopic=179461
mines on 40mm lowering springs and .............it handles like shit! the springs are to hard for the dampers so it bounces like crap wen driving round the twistes but on normal roads it is fine. i eas like you and just wanted to be lower for cheap but its costing me more in the long run because I'm guna have to buy a new set now!
i will not buy coilovers because i am not intrested in being low i want to my car to handle good inste,d and a decent set of matched shocks and springs will be miles better for 300 than a pair of coilovers for 300. but it depends what you want weather you want
1. to be low = coilovers
2.road holding= good shocks and springs
but I've ended up buying lowering springs and and shock and spring set so I've spent more :lol::lol:
Ah right, ok...I didn't realise coilovers would make the handling worse...?!
I'm sorry but a set of £300 coilovers will not handle bad at all.
na dude they wont they will make the handling better but for me as i want improved road hoalding if i was to spend 300 i would spend it on a matched set of springs and shocks because i dont want to be able to adjust my ride my height as i live in mountains lol it depends what you want
didnt say they would :?
I've got a good comparison between springs and dampers vs coilovers as my scirocco has coilovers (albeit cheap ones)
Coilovers are good for height adjustment (dial in perfect stance) and improve handling no end, the only downside is with some of the cheap ones, they can be very stiff
Springs and dampers to the same for the handling as coilovers but to a lesser extent and are usually a little more forgiving in the ride department (unless you're willing to spend £500+ on coilovers to get the best ride)
Shame you're in London, I'd come and help fit coilovers for you, done several mk4's!
