Mk2 polo cup holders
right wondered if anyone has put cup holders in there mk2 thinking about putting some in but dont want it looking as if i crashed into halfords :p
if got any pictures put them up or ideas thanks alot 8-)
Tom
  • Views 2.9k
I just find it amusing that one of your priorities with your mk2 is to fit cup holders, it would probably come in last in my list lol.
You got a centre console? something could be done with that, maybe holes cut?, I've a fire extinguisher in mine.
black universal one in the center console is about the only choice isnt it , could blend it in to the console with filler and spray it black if you wanted
Screw a push bike bottle cage to the dash..
I find the centre console perfect for holding my litre cartons of juice and two pint cartons of milk,so it depends what drinks you go for.
If coffee from the expensive bean cafe then just hold it between your legs - warms yer nads up and makes you drive more sensibly.
haha yeh man its just annoying when your on your own and go to mcdonalds got no where to put drink :p
Maccy dees? Burger King are far better..
Got a couple of ideas.
If you capped the console with a top plate,then cut a hole in,that should work? Could even make a slider to cover the hole when not in use,or fill the void with composite and cover it in vinyl to make it look OEM.
Alternatively,remove the centre console and make/fit upright cup holders to the floor.
You can get universal plastic ones that hang from the door where it meets the glass,but they dont fit the MK2's doors well.
I put a foam one inside the glovebox lid of my first car,and it worked okay until i braked - the coke dived in the glovebox,and pulled the lid shut behind it.
Whatever happened to those balancer ones you could get? The drink tilted into corners like a biker as you went around corners - very clever. They worked,and were popular before cars had cup holders. That'd be ideal for the console.
i am tempted to buy some genuine porsche 911 cup holders they look as if they would go well on the side of centre console
23660_378701966735_719376735_4225913_324
