will these wheels fit my car
hi,
i am looking to buy a set of rh cups and they are 15x8j and have 205/45/15 tires.
they are 4x100 so i no they will fit that way, but the offset is et45. will this effect if they fit?
i have a polo 6n 1.4 16v.
also my car is lowered by 30mm so would this scrub on my arches
any advise would help i have tried find out.
many thanks
Edited by rozza92
  • Views 942
thats an insane offset...youll need to run spacers as they will rub on your suspension struts...youll be talking about 20mm spacers
wont scrub at 30mm, youd be looking at scrubbage at about 70 + mm
plus you may want to change the tyre size to 195/45s which will offer better clearance also
defo need some spacers, but 10mm should do it matey and no need to change tyres as there te recomended standard width for the size of wheel, but if you need that extra little clearance, then 195s as above will give a little stretch.
Ok thanks, i will look into getting some spacers then maybe
