spraying help please
I'm abotu to start spraying my arches but have noticed on the cans it says I cant lacquer it till the paint has had 24hrs to dry??
can I do it before that as If it rains I'm fucked
  • Replies 12
  • Views 1.4k
thats balls ...laquer after 20-30 mins no probs
aslo I heard stuff like you need to wet and dry the paint down to matt the get the gloss finish?
base coat , then clear ..no sanding between the two
if once its all done its a bit peely , then 2000 it and polish it up
spot on mate thanks for all that going to get on it today
Hmm started by sanding down the primer all looked good then added the paint and you can see a line where the primer is will that buffer out?
no need need to sand the primer properly
so strip what I've done to the primer and sand it down smoother and re-apply paint?
let what youve done dry...so 30 mins or hour
sand it with 800 or 1000 wet n dry so that the line is gone and feels totaly smooth all over
then basecoat until covered , wait 20 mins and clear coat it
Legend Just done the sanding the line has gone
just worry about the line when I take the tape off
I'm SUCH A NOOOB
thanks for the help buddy top man
are you saying you have masked a square around the repair and painted up to the line?
ahahaha made me laugh, dont know why , but yeah this man is right!!
It looks half decent think It just needs a good buffer now!
