86c
Hey guys, i need some answer and advice...
I got mk3 86c with 1.1l engine, and i got another one mk3 gt 1.3 and i want to swap the engines. i want to put in mine 86c instead of 1.1l engine, the 1.3l gt engine.
question is, will it fit without any problems ? will i have to cut anything ? or just "pull and plug" ? Thanks in advance, Zlatan.
  • Views 976
you'll need everything from the GT engine (engine, gearbox, loom, fuel pumps etc) but yeah, it'll go in easily. Been done god knows how many times by people on here.
Thanks for the reply.
Yes, thats what i ment. to swap all the parts... i was just wondering if theres going to be a problem by fitting it in, would i have to trim the firewall or something...
Again, thanks for the reply,
Zlatan.
shouldnt be any need to trim anything.
Remove old engine, gearbox, loom etc and fit GT engine, box and loom.
Should roughly take a day to remove and fit the engines and then maybe a day or two to get it all wired in and running perfectly but that all depends on your mechanical skills.
Please ask engine questions in the engine section.
