About to attempt a cambelt on my 16v
I'm about to attempt to do the cambelt, water pump and a full service on my 6N 16v. Has anyone got any tips?
I'm reasonably mechanically competent (I've built engines before but never done a cam belt) Is there anything special on the polos or anything I'm likely to miss?
  • Views 1k
Line the timing marks up first,then lock the two cam wheels together if you can,before removing the belt.
This is because its tricky to line the wheels up when putting the new belt on if they're not locked.
I use a nut and slot bolt,torqued only by hand,to act as a lock between the cam sprockets. I think they're M12.
Also,dont be alarmed if the new tensioner has been made with the outer surface cross buckled. This is normal,though i dont know why. I saw the old one first and thought it was just monumentally worn! :shock:
the timing mark on the bottom pulley is one of the teeth having a chamfer on one edge, this lines up with a mark on the block (I didn't know this when I did mine and nearly nadged all the valves)
PLEASE!! make sure when its all back together that you rotate it by hand, then you'll see if anything is not right, if you just spin it on the starter and the timing is out you'll whack valves into pistons....
steve
Please ask engine questions in the engine section.
