6n rear lights on a 6n2?
I know you can fit 6n2 rear lights on a 6n, but was wondering if you can do it the other way round cuz i found these and really like them but they say they only fit 6n
vw polo mk4 black rear lights
or do they make these for 6n2?
thanks
  • Views 1.7k
bit of an iffy one mate, cause if you have to remove material from 6n2 lights to get them to sit flush on a 6n, surely 6n lights would sit shallow on a 6n2?
tint your lights you have yourself?
the wiring wouldnt be a problem, just the reverse of 6n2 onto 6n, I'm sure theres someone local whos got some 6n standard lights you could try first?
I could get them sprayed gloss black by my mates dad. But I like the look of the smoked ones more.
the only one of my mates with a polo also has a 6n2, so can't really get hold of any 6n lights :/
It would be ideal if I could get a set that looked like the smoked ones, but made for 6n2.
thanks anyway mate
them ones you linked look like the white crystal ones been smoked, you can buy different grades of tintin spray.
you got a local scrappy?
they stick out a tiny bit but it is bbarely noticeable, and there is small wiring mod needed in the boot but it is fairly simple to do
