how do you change dials
I bought some white dials of eBay for my 6n just wondering if anyone has a tutorial on how to change them.
  • Views 803
Bumpy bump
take the clocks out, do this by un screwing the 2 screws under the top edge of the clock surround, then you need to lower the steering wheel and you'll see 2 more screws (1 either side of the clock surround) un do those screws, then the clock surround will pull out, you need to manover it around the steering wheel.
then you'll see 2 more screws holding the clocks in at the top, un do these then you need to pull the top of the clocks towards you whilst pushing the bottom of the clocks up.
then just un do the plug at the back of the clocks, there's a clip holding the plug in, all you do is push the clip back and the plugs pops itself out, you need to manover the clocks out of the gap in the dash and from behind the steering wheel.
then there's 4 screws on the front on the clocks holding the clear front on, take that off, turn the clocks over and undo the screws on the back, your clocks will now pull apart and you can change whatever you like :)
NOTE: the screws will most probably be torx (not good at spelling it) bits, were torx bits on my clocks but have seen screws on some others.
Edited by matt-polo-6n
