time allowance for wash+clay+polish+wax
hey,
thinkin of doing my car tomo.
id give it a wash first,
then i want to clay it, polish it, and wax it, how long would people say it would take?
and will clay leave marks on black plastic?
ta
  • Views 989
6 hours-ish if you do it properly..
And try not to clay textured plastic.. it shouldn't stick when it's lubed up but best to try and avoid it anyway.
was just thinkin difficult to avoid bits like things you tend to catch when polishing etc :)
Whack some masking tape around the edge of stuff you dont want to catch with polish / wax..
The proper blue stuff works best but normal stuff will do the job..
things i catch are jus the roof strips & window seals really :)
Shape the clay so you avoid contact with plastic / rubber if you're worried. It's not really going to harm it unless you don't notice you are rubbing it.
Probably 5/6 hours as said above.
well iv now washed it,
i can normally polish it in about 1 1/2-2 hours, depends how bad it is
so i should imagine il get it done fairly easily :) id like no sun but dry :)
