How do i remove the pipe that goes from the power steering pump across the front below the rad
the pipe that goes from the power steering pump across the front below the rad then behind the battery tray, around the back and in to the rack. Mines pissing fluid out from the rubber part at the front and going to try the scrappys
  • Views 773
any one no how they connect iver end?
metal unions, use a spanner to undo them
