mk2 loon to gt
just wondering what i would need no convert my 1991 mk2 loon into a gt :-) . do u just need the engine or do i need all the loom and everything like that. because I've been told that you only need the engine by a few people and it would fit straight in. cheers
  • Views 810
would need the wiring loom too nearly all of it!
the people who told you the engine bolts straight in are right its a drop in job but you then need all the associated fuel injection parts.
as there is the inline pump and the in tank pump which need power and feeds.
as well as most of the injection bits that live next to the spare wheel
any mk3 can donate most of the bits you need except the engine bay wiring loom (fusebox forward), inline pump and complete engine and box which are GT specific. ( can use a NZ and G40 pump they are all the same thing!)
likely also to need the 2 speed fan and fan temp sensor available in most 90-94 VWs!
if u see a MOT failure GT or accident damaged one best buy it and strip it keep the bits you need and the bits you sell might even pay for it :nod:
Edited by genesisGT
