got a puddle in n/s footwell
Just wanna know what to do firstly how to get rid of the puddle and also were the leak is comin from and how to stop it ......do i ha e to take all the carpit out :-(
  • Views 1.2k
bump ??
Sounds like a blockage in your scuttle draining system. Take out the scuttle (black piece of plastic under windscreen) and remove any leaves or debris. Then replace your pollen filter, should sort it.
kll will give it a try thanks :)
Don't forget to flush the side gutters with warm water until you're sure water drains away freely from the scuttle. There is often a big glut of leave concreted in there and hidden from view. This one, I had to learn from experience.
PoloD.
to get rid of the water.... shoot hole in the footwell :D
jokessssss
jokessssss
TopGear ;)
