Horn broken 6n
My horn has been broken for a while now, and am gonna look into fixing it now :lol:
I know it could be the fuse or the actual horn? But how do i go about looking for the fault. Cheers
  • Views 900
If you've got a multimeter or test lamp it should be easy enough to find. First check the fuse by looking at it, you should be able to see if it's blown as the conductor will be broken.
If not, unplug the horn and put the multimeter or test lamp across the two pins. When pressing the horn button (ignition on) the multimeter should show 12v or the lamp should light up. If it does then it's the horn. If it doesn't then it's either wiring or the switch.
HTH
Ray
Cheers mate,
I've got no idea on where to find the fuse though? Is it in the lower dash, or under the bonnet?
Sorry got no idea on a mk4, searching on here will probably give you an answer though :thumbsup:
