Condensation!
yeh basically my boot carpet, after a short time....gets pretty damp, I'm 99 per cent sure its condesation...why does it happen in my boot and how can i stop it, any help appreciated x
Whip all the carpet out and see if you've got any holes or rust. Also check the underside for damage.
As a short term solution you can buy dehumidifiers containing dessicants for use in cars. My brother has one in his golf and it stops it from fogging up even when full of damp wetsuits. Its a kind of cushiony thing that looks like a draft excluder
I've taken carpet out and dried it out, cant see any obvious places it could be coming in from, I'm a surfer but never get the boot wet....
.I'm thinking it could be down to the cold weather we've had this winter,
and/or the exhaust get warm and my cold boot meeting, causing the condensation???
Edited by willirons
You could try looking at the lock seal, mine was shot and I think the condensation has reduced quite a bit since I changed it. Can't be sure but it would make sense.
mine leaks through the seam below the rear light cluster, have re applied seam sealer. Its had a small rear end bump at some point though.
hmmm, just had a good look over the car and cant see anything obvious, i reached up in by my light cluster and its wet both sides all the way up not soaking but muggy...which is why I'm sure its not a leak on a seam.....I'm pretty sure its only been happening over winter when its cold too, and i only drive early mornings and evenings really. going to to get some selica gel crystals or something and see what happens. may just go check all seals again. thanks for your help...its a mk3 gt btw if anyone else has similiar probs
peace
strip out the trim and carpet etc and climb inside the boot and get someone to hose around the boot, rear lights etc and you will soon see if you have a leak
good plan!
