25 pound digital AFM guage - ebay special
your thoughts on a postcard please,
was on a random scout for guages on gaybay and I've been after a wideband guage and sensor for a while, check out the link below, i dont have a turbo so I'm seeing if they the AFM with any other things like oil pressure or temp, or exhaust gas temperatures, but for 25 squids I'm gonna take a punt anyway when this geezer gets back to me
http://cgi.ebay.co.uk/Digital-Air-Fuel-Tur...=item25578d8cc6
oh and check out this random wannabe stack clock system
http://cgi.ebay.co.uk/Multi-Function-Displ...=item2a0586d60e
  • Replies 8
  • Views 1.6k
i've had a look at them before whilst looking for gauges. Looks abit tacky to me but for £25, you get what you pay for.
Let us know how you get on Saf ;)
looks narrowband to me.
Looks like narrow band to me, just wires into your current lambda sensor and about as accurate as Safs description of his own penis
i cant see it when its inside your mam ant =D
bam, where have you been hiding anyway boyo, get involved!
hmm narrowband eh? i know not the differences, will have to go have a read
safos
and surely even some sort of vague accuracy is better than guesswork, or dizzy tweaking an razzing around
Edited by grungeisdead
ok right, I've done some reading and a narrowband is a 0-1v signal and wideband is 0-5v,
I've found a cheap lsu4 bosch wideband lambda sensor, so just need to find a suitable guage or just buy a complete kit from the off
edit bumbadgers is bottom line you need a controller, cba spending that kinda money at the minute, and no worth bothering with a a narrow band
ignorance is bliss as they say ;)
its quite simple to get your carbs running riight you crazy sukkah, carbs should sound nice and 'wet' not mettalic when revving and should run right upto 7-8k without flat spots and timing needs be done by ear
13degrees advance heeerree we cooommmeeee
they do go up past 7k =D brap braaaaaaaaap, I'm not rocking vac advance at the minute and think its setup for 12 degrees advance at idle. i need to stop being a pikey and put the proper octane fuel in there haha.
and i dont have any apparent flat spots but it just doesnt feel right, i think the fact I'm on standard jets and needles doesnt help, still goes well mind, i need to take you out in it ant
lets do it then, bosh me a text and I shall rate
