83 Mk1 Golf
Well bought the car last week in February, had problems since the minute I got it
Here’s an overview of the specs
Was originally a 1.1 with a 4speed with 127,000 miles with a Webber carb
It’s now a 1.3 Mk2 Polo Coupe S with a 5speed and 88,000 miles
GTI Front Brakes
Mk2 Golf Pirelli P-slots
GTI Rear Bench
Installed my sub/amp and H/u too, which are hidden by a false floor to keep a original/retro look
Just need to make some clean door pods to house my components
It has a few things which I want to do, to get it looking decent-ish… lol
Which are;
Orange indicator Lenses in front bumper
New plates without the stupid markings
New CL Splitter
New drivers Side rear cluster
Repair black side strip so it clips back on
GTI Front Seats
Source a P-slot Centre Cap
Add Gauges
That’s my list for now, until I have more free time and money
Well here are some pictures from when I bought it, to where it’s at now
How it looked before I picked it up 
And now I have it
It came on some wide steels (not banded still wide though)
P-slots on and a clean
Starting installing ICE too 
Fully Trimmed
And my progress on door pods; need to get some pockets so I can blend it in with some fibreglass
My work may look messy, but its best I can do, I'm not a very practical person at all, more into the technical and design side of things, and without forking out for a professional or asking people constantly this is the best I can do
Engine conversion
The car that brought the engine home, 895CC Mk1 polo
Engine out
Nearly in
In :)
Just a few bits need doing
And heres a list of what needs doing to get it running
Coolant Block from Coupe S needs to be taken off and swapped with the Mk1 one
Radiator put in
Choke sorted
Extend vac Pipes and connect
Extend Fuel Pipes and connect
Speedo Drive cable
Fit new throttle cable
Wire it in
  • Replies 18
  • Views 3.4k
looking tidy mate, mk1's look sweet in black and those steel's worked really well on it, still looks nice on the p-sluts mind.
your handy work may not be show winning but at least your getting stuck in and doing it yourself mate, you'll get more from it doing it yourself than paying some one else to do it imo :thumbsup:
Cheers dude, i wanted it with the original wheels but just couldnt afford it, so i put my p-slots on :)
just picked a roof rack Orange lenses and heat knobs
Got a new Rear Cluster on the way
Just won a Splitter
Got a AA relay badge for retroness looks
and going to order some top caps later to drop the front a wee bit ;)
Gave the car a huge detail today (in my eyes)
Heres some photos i took while i was messing around
And my lovely flat tyre :@
Heres my list for Alltypes updated
Roof Rack
Orange Lenses
Heater Knobs
Degreased Bay
Paint some things with engine bay
Get it running
Respray bottom of boot
new Number Plates
parcel Shelf Support
Rear Light
New Wipers
Thats it :)
I've sprayed the rocker cover and fan cowling the colour there going due to it being VHT paint, but the airbox needs to be changed as its too matt, will go satin black :)
Fitted my roofrack,
Should have it running tomorrow :D
Plus hoping my new rear light, splitter come, and then ill fit them along with a AA Relay badge for abit of retro looking, and my orange front indiactors ;)
Cheers it didnt come with them
Came with some 14" Van steels that are like 5.5J wide
Got a bit more done today
Only a few little bits to do...
Mk3 Polo Throttle cable (need one and then Fit)
Mk2 polo Ignition Amplifier (need one and then Fit)
Wheel Bolt (need one and then Fit) this will block a unused vac pipe
Check fuel pipes are correct way on haynes (anyone able to check this for me)
Ignition Live needs connecting at back of carb
Ignition Live needs connecting at heater solonoid
Reverse Light
New HT lead for Coil
Speedo Drive
All little bits now, but it turn under key, just no life yet
Love this wee car, good progress keep it up :thumbsup:
why no life mate? lurve mk1's had 6 or so now. :-D
Olly
Cheers :)
Olly
No Life :s ??
Yeah mk1s are ace :D
regards to fuel pipes, if you take off the one to the pump and blow back down it you should hear it bubbling in the tank if you got the right one.
and trying to remember when i converted my first mk1 to 1.3 mk2 polo lump (10 years ago), but i know i had to change the coil, it wouldn't run with the mk1 coil as it was different type for points. also one of the wires that supply the coil ( i think it was white ) doesn't supply enough volts (iirc ~10v) and you need to run a 12v live feed from the ignition in place of the white one.
will also not / struggle to start without the idle solonoid connected on the back of the carb, again a 12v ignition switchable live.
Olly
Olly
Yeah it has the mk2 coil on it :)
And yeah to get those other ignition feeds we need some more cable, just unsure what type :/
Hopefully have it running soon :D
good luck with it bud, hope you get it running soon.
(have you cut the bit of plasic off the gearlever box to get 5th? :lol: )
no, but it goes into 5th fine :s
some do some don't. :-D
Cheers for the help :D
If you remember anything pm me :) for tips lol
Am i correct in thinking that the module i need (Ignition Amplifier) i can use a Mk1 GTI one?
If so it may fire up tonight :D
Luke
how easy was the engine swap? I'm trying to find a mk1 golf myself after the chassis snapped on my gt and i am plannin on puttin my gt engine in the golf which i purchase. how do you get the original engine mounts to fit the gt engine so you can bolt it into the golf.
The gt engine is from what i know alot easier than what I've done, but is slightly different, best bet is getting on the Mk1 Golf OC and asking there, i was going to GT mine but insurance would be raoe!
ok, cool
Well it now runs, new coil, timing done, new plugs, leads, cap!
All new anti-freeze and oil
painted a few bits pikey style for now ;)
And gave it a clean, as i thought it was going to be going alltypes but wont be finished in time :(
So heres how it looks and whats left before it can be driven on the road. . .
Engine needs a new manifold gasket - as when it comes off choke its cutting out due to blowing...
Need to either make a custom throttle cable from a Mk1 golf one and Mk2 Polo one of get a Mk2 polo Bar and pedal
Need to get airbox and air filter in (new airfilter needed)
Sort out the selector, as where reverse should be is 1st and 2nd then where 1st and 2nd should be is 3rd and 4th etc etc leaving me with no reverse
and sort out my temp and oil senders, as there not working, temp one seems to go straight up off the guage without the engine even started and warmed up. and the oil just flashes, mechanic reckons there earthed somewhere, so once i have the money ill book it into a garage for those ;) ohh and sort the master cylinder and new disks/pads etc!
So nearly there, just need to wait till my next income of money now :p
