Mk2 coupe
Depending on the source its around 750-790 :)
do you think 550kg is a realistic target then ?
  • Replies 55
  • Views 9.6k
wouldn't it be easier and a bit more comfortable to get another 20 bhp?
lol
make sure you always take a dump before you drive it
btw just to help you out a bit I found somewhere that thinks it's 725kg
http://www.carfolio.com/specifications/models/car/?car=39292
not sure if that's a wet or dry weight (with/without fluids)
hopefully will put my twin 40's on it
4269_208656900192_551975192_6847695_4286
they need rebuilding though.
but i really want a 1.4 16v, thats why I'm not too bothered about engine work right now .
I'd say you'll struggle to break below 600 kg unless you plan on fibreglass panels.
u could just take a drill to the whole car...
Roof chop it and make it a bit shorter. That would get rid of a lot of weight....
f/g bonnet and wings ftw
planning on drilling holes in certain places. where do people get ther fb panels from ?
collected toyo r888's from max crox today :)
dont drill holes in the r888s!
If you put go faster stripes on it sideways it will float upwards wiki says it's true so try it you will save lots of weight. http://en.wikipedia.org/w/index.php?title=...fulltext=Search
This is a cool project I wish I could find a mk2 coupe for 90 squid!
Haha good man, ilike it, as previously mentioned, wet n dry weight, u aiming for 550 wet i presume?
Y cut take out tge fuel tank, and half it, that would save a bit, i wouldnt sheer off too much off the body tbh will male it floppy espeshally when u get a bit of torque thru it or thru corners lol
good luck thouhh
hmmm not too many holes drilled into the r888's there 7.9kg each
maybe i was dreaming a lil when i said 550kg fml
good luck thouhh
fuel cell might be lighter?
valver lump it then bring it to cov 8-)
chris why were you up at 4:30 dude ? and i dunno whther to bring it to cov as people could take off my boot and bonnet as they will be pinned on ahahha
ahh fair enough lol, yeh that could be annoying with the bunch of scallies that live in raglan!
and i really have no idea why i was up that late, just a bit of general polo whorage i guess :lol:
was thinking about those lockable aero catches but there a tad expensive
Buzz - hows it hangin fella.
Was you at elsecar at weekend, possibly saw you but wasnt sure if you'd gone or not!
Shorten every bolt by 2-3mm lol
hey neil, didnt make it to elsecar most of my mates did like. might be making the polo show for the first time this year though
I'm tempted on chopping bolts haha
Sure man, see you at poloshow for definate!
30079_10150207813040193_551975192_126190
30079_10150207813025193_551975192_126190
30079_10150207813035193_551975192_126190
30079_10150208836030193_551975192_126415
30079_10150207813045193_551975192_126190
as you can see i have the wheels painted and r888's fitted. also painted over the polished part of my raid 280.
philj kit has arrived 80/60 kit if i haven't written that already.
sourced a 4speed gearbox for free. interestingly 4speed gearboxes hold 0.9 litres less oil than in 5speed. lightweight baby :)
painting of the car should start within two weeks
28129_10150209352850193_551975192_126554
forgot to post this. these are the pins i will be using for the bonnet(4) and the boot (2)
ditch the bonnet and replace it with perspex with a pin in each corner, it would be a hell of a lot lighter and you could see through it as an added cool little twist :lol:
this should go well with a valver lump in it, although isn't fitting a 4 speed box a little counter productive? they may weigh a little less but the gearing after 2nd gear is shite. my mates mk2 had about 70bhp and it was quick in first and second, but after that the gearing killed it
the main reason isnt for weight, for some reason i just quite like 4 speeds.
i have a choice of 2 other 5speed boxes so if it is crap will just pop it off
