can you fit 6n seats in a mk3
please answer me this as the seat subframes look the same to me as my ibiza seats had the same sort of set up if they dont fit would it be hard to modify the seats frame to go in the runners on the mk3 the seats in my polo are to low on the back or are there high back polo seats that fit
  • Views 889
someone must know
As nobody seems interested I'll have a stab at this so bear with me.
It seems that the only seats that fit straight into a 6n are 6n/6n2/Golf3/Corrado/some Seat. If mk3 seats won't fit in a 6n then the reverse is also true.
I'd guess that mk2 Golf seats will fit straight into your car.
not a direct fit, pretty much the same but the rear spacing is either shorter, or longer between the mk3 and mk4 models, nothing a bit of cutting and welding couldnt sort mind but it wont be plug and play =]
