Sticking indicator help
my indicator stick doesn't click back after a corner when I indicate to the left, but it does click back when I have indicated to the right.
any ideas what it could be before I strip it down?
thanks
  • Views 899
Mine is exactly the same! On my my mk2f i adjusted steering wheel just made sure it was bang on straight but unfortunately still no luck i just see it twitch lol.
so as usual no one helped... sorted now anyhow
worth cleaning the stalk mechanism with some wd40 and toothbrush ..or airline blast it
how did u sort it then?
ye you gotta get the steering wheel off, undo the 3 flathead screws and unplug the wire connectors (x3) to remove the arms/switches unit. Both arms separate from each other when you have done all that.
theres a little white latch that moves the switch back to the off position that had moved out of place. Put it back and gave it all a good clean up.
also realised my steering wheel latch wasn't quite far enough into the hole to catch (the white catch on switches) 100% every time. I made a little spacer out of easter egg case plastic and put it between the switch unit and where it screws down to. That pushes the switches away from the dash just enough, further up the steering column, toward the steering wheel
hope that helps
