NEED HELP! RETRIM
How do you get the carpet the headlining and the door pillars abc pillars out of a 6n?
also will any sort of fabric that i want to use for the headlining and the carpet work if it is cut to the same size or can i only get existing 6n carpet to fit?
i also want to remove the pillars, where abouts are the clips for the pillars because the last thing i want to do is snap off the clips?
also how do i get the seats out of the whole thing because i presume i will have to take them all out so that i can ft the new carpet...
i need to also know how to get the rear door cards out of a 6n three door as i've loked and can't seem to figure it out?
also would like to re-trim a parcel shelf...
  • Views 1.3k
Headlining comes out after all the pillars, visors interior light and grab handles are out.
Clips are pretty tough so they're not gonna snap easily. I've had my pillars and headlining out loadsa times, infact the whole interior is out right now being trimmed.
Seats come out by undoing a little holding nut at the front of the runner. Once you've un-done that the whole seat will slide all the way back and then you can lift it out of the car.
Rear door cards are easy enough. Will be a couple of grommets blocking off screws and another screw near the bottom somewhere probably, then it just clips out.
Your not asking how to remove the parcel shelf are you?
Headlining you can use any fabric to be honest. I've seen loads of dodgey materials used on them. Personally I'd use High quality vinyl, around 20 quid a metre. The cheap stuff ain't all that.
Faux suede isn't that bad and it looks good, about £5-8 a metre
When i asked about the parcel shelf i meant does anyone have any suggestions on fabric to re-cover it?
do i just pry the pillars off with a flat head screwdriver?
No you pull them off with your bare hands!
I'm not joking by the way. It will hurt a bit especially when your hand slips and gets cut on the clips but it's the only way!
screwdriver...plastic....levering...strong clips...think about it petal :)
