quick question
hi guys.any tips because i havn't yet found a haynes manual to help me out..what do i have to remove to take it off? regards,Baz.
  • Views 769
not to bad, most of the botls are obvious, you have to take the wheel arch lining out and there is two bolts, that have sealant all over them, you have to try and clean it off and remove the bolts. then get like a wallpaper scraper thingy and work it behind the wing to remove and sealant, being carefull not to bend the wing.
Tommy.
