Hello all
Hello, please allow me to introduce myself. My name is gordan (not gordon, gordan :D ), and I'm from Croatia, and whats most inportant, i own a 1993, Brilliant Schwartz Polo coupe. 1.0 is the engine (not the strongest and id love a 1.3 but this one - when its working - makes me just as happy)
What have we done to the car so far? just the basics, new ngk sparkplugs, oil and filters changed, new clutch, moded the exhaust, and resprayed (although poorly) the whole car. I'm going for the gt look, so I'm visiting the local scrapyards (mostly in italy though) for all the gt stuff, all i need to finish are the seats and door panels, and ill be happy with it. whell heres a few pics...
before:
th_37493_DSC06364_122_509lo.JPGth_37511_DSC06365_122_513lo.JPGth_37530_DSC06367_122_418lo.JPGth_37547_DSC06370_122_119lo.JPG
th_37565_DSC06371_122_339lo.JPGth_37581_DSC06372_122_188lo.JPGth_37599_DSC06373_122_458lo.JPG
th_01168_DSC06378_122_592lo.JPGth_01176_DSC06379_122_488lo.JPGth_01184_DSC06380_122_47lo.JPGth_01193_DSC06381_122_91lo.JPG
th_01200_DSC06382_122_429lo.JPGth_01208_DSC06383_122_389lo.JPGth_01216_DSC06384_122_1070lo.JPG
Cleaned the inside:
url="http://img153.imagevenue.com/img.php?image=57154_DSC06393_122_721lo.JPG"]th_57154_DSC06393_122_721lo.JPG[/url]th_57161_DSC06395_122_719lo.JPGth_57171_DSC06397_122_918lo.JPGth_58204_DSC06400_122_1113lo.JPG
Cluthc change:
th_67764_IMG0031A_122_459lo.jpgth_67771_IMG0032A_122_393lo.jpgth_67777_IMG0033A_122_522lo.jpgth_67783_IMG0034A_122_596lo.jpg
Then started some body work
th_90774_DSC06416_122_121lo.JPGth_90783_DSC06417_122_494lo.JPGth_90792_DSC06418_122_72lo.JPG
Then i got a old gt whell which tbh i like more than the newer one
Then more of the re-spray
th_52857_IMG0060A_122_104lo.jpgth_52861_IMG0061A_122_22lo.jpgth_52866_IMG0062A_122_127lo.jpg
th_52870_IMG0063A_122_455lo.jpgth_52875_IMG0064A_122_536lo.jpgth_52880_IMG0065A_122_354lo.jpg
th_50424_Slika050_122_478lo.jpgth_50428_Slika051_122_470lo.jpgth_50431_Slika052_122_366lo.jpg
th_50435_Slika056_122_61lo.jpgth_50439_Slika057_122_693lo.jpgth_50443_Slika058_122_115lo.jpg
th_50447_Slika059_122_41lo.jpgth_50452_Slika060_122_860lo.jpgth_50458_Slika062_122_4lo.jpg
In the end it ended up looking like this: (plus the wheel arch plastic which i fitted on later)
th_19408_DSC06446_122_519lo.JPGth_19419_DSC06447_122_114lo.JPGth_19428_DSC06448_122_1178lo.JPG
th_19440_DSC06449_122_545lo.JPGth_19450_DSC06450_122_243lo.JPGth_19462_DSC06451_122_39lo.JPG
th_19475_DSC06454_122_1169lo.JPGth_19486_DSC06455_122_885lo.JPGth_19498_DSC06456_122_397lo.JPG
th_19510_DSC06457_122_361lo.JPGth_19522_DSC06458_122_200lo.JPGth_19532_DSC06459_122_381lo.JPG
th_19543_DSC06460_122_396lo.JPGth_19555_DSC06461_122_893lo.JPGth_19565_DSC06462_122_592lo.JPG
Sadly the lacque went heavy-duty-orange-peel on me, but i dont mind, i need to fix all the mechanical problems and than one day ill hand it over to some pros...
Thats all for the introduction, now for my current problem, I've read many people had similar problems but no one wrote anything about how they fixed it. thing is, when i start the car cold it works fine, revs fine and all, and then when it warms up it starts juddering and then dies. I've replaced the injector but it dint help, i replaced the ecu (i had a spare) it didnt help, i replaced the blue temp sensor still nothing.. tommorow I'm going to a scrappy to buy another throttle body and fuel pumps, becouse i noticed that when it dies, and i try to start it no fuel is sprayed out of the injector, and then if i pour some fuel in it fires up briefly... oh i also replaced the fuel pump relay...
any ideas would be of great help.
well thats all from me. i hope you guys dont mind a foreigner in your midst...
Cheers lads, Gordan. :-)
  • Views 1k
Welcome!
welcome, car looks lovely :)
unfortunately, i cant help with your problem, but i'm sure soon enough someone will have the answer :)
Thanx people. :)
@j-low, dont worry about it, ill figure it out sooner or later :smirk:
Well i think I've traced the problem down to the lift fuel pump, as there is no response from it when i connect it to 12v or when its supposed to run in the car. What i dont understand is how the line pump managed to supply the engine by itself? ah well, ill replace the lift pump and move on from there, thing is they're really expensive so i have to trace down a used one...
Yup, twas the lift fuel pump... back on the road, now back to happy polo-ing :D
  • 1 year later...
nice gt
what splitter are you using?
