ANOYING RUST!
Just bought first polo, and there is a small preety minor patch of rust on the wheel arch, although its nothing major its enough to be able to notice and irritate!
Whats the best way to deal with rust? Without doing anything major!
I will upload a photo tomorow!
Thanks!
  • Views 1.4k
Id like to know the best method for this. I've heard various ways but whats the general feeling?
best way i have found if it not rotten away and doesnt need to be cut out, is to sand it down to metal put some rust treatment on, primer,spray, lacquer, obvisiouly more to it than that like sanding down inbeetween coats of paint
Ok yea thanks mate, going to have a go at it tomorow i think!
:thumbsup:
What rust treatment people reccomending por-15 maybe ?
You really need to remove every last bit of it then treat the area with phosphoric acid (Jenolite is perfect for this). If you leave any rust behind, it'll startup again and ruin your hard work. Try a small grinding wheel in a drill to remove the grot. Fill, then paint...
The other product other than rust converter (like Kurust) is Deox Gel from Bilt Hamber which is a paste (like wall paper paste) that you put onto the rubbed down area, cover with cling film over night and it draws out the rust like a poultice. It's amazing stuff, you can buy liquid stuff as well for small parts but vinegar I believe works for that anyway.
