Removing Mk3 Tailgate
i took one off in the scrappy today, but i just ripped the headlining and wiring out of he donor, obviously i don't want to do this on my own car, so how do i go about getting to the bolts? remove the boot seal and peel the headlining back? any help appreciated
cheers, rob.
  • Views 1.4k
That's the one :thumbsup: Get the glue warm (not hot) and slide a blade behind the headlining.
Wring and washer hose are the main problems because pulling the loom out and getting it back in the right place is a pain in the arse. I generally leave myself some spare wire so I can solder it up and clip it in the hatch frame.
if you disconnect the wiring plugs near the rear light, you can pull the wiring up through the top if you're carefull.
right, nice one lads. i'm going from a smoothed tailgate, to a standard one, de-wipered, am i right in thinking the only wiring on the top left hand side of the tailgate is for the heated rear screen? i have no washer pipes to plumb as they have been stripped previously...
No. plate lights
No. plate lights
my plate lights are in the bumper...i haven't traced the wiring tho
