Has any one got any pics of there own arch rolling ?
  • Replies 14
  • Views 2k
bump, iv been looking for the same :)
i think I'm gonna make an arch roller (wheel spacer welded onto car jack with a reel on the top)
or use a mallet. lol
ye sounds too complacted lol. Am saying the mallet
the homemade rollers actually really simple, ill try find a pic .....
yer defo worth trying to make your own.
dan :-D
Edited by polodan2009
lol u took to long haha :D
shouldent be that hard to make one
dan
dan
yea looks easy enough, and if it saves us nearly 300 quid then its well worth it!
pretty sure would easily sell it on too
:thumbsup:
some one had a few pictures of there arches after they used a mallet but i carnt find them it was on a white 6n on gallery
I didnt take pics when i did my 6n arches with an angle grinder and a mallet 3 years ago but it was my first attempt and looked shit.
I have got it donwn to more of an art now but rears are harder cos theyer thicker skinned.
I find the easiest way is to run the grinder long ways along the arch as close to the outer edge as you dare to make the metal thinner but dont cut through, this gives you a weak section where it will start to bend and just keep hitting it till its rolled all the way up. Give it a good few coats of hammerite to stop the rust and jobs a goodun
So do I run the grinder long ways along the arch. Asin the inside of the arch or the outer .. explain more please :)
youl want to run it on the inside dude, and i believe by long ways...he means with the disc flat to the arch.
But in all honesty it would be easier and less likely to cause serious damage making the diy arch roller and using that. Plus if you have a heat gun handy, warm the paint on the arch up as this will make it more flexible and then as your rolling the arch, if you do a good job and use the heat gun properly you will minimise the chances of paint flaking and thus having to have the arch resprayed. I've managed to use an arch rolling tool in the past and a heat gun and not damage the paint at all.
Edited by Monkey-man
i wwould try make one but i have all most none of the stuff to make one or welding tools
the stuff is cheap enough to buy and I'm sure that a garage will weld it together for you for a couple of quid.
Plus you can rent arch rollers and youl get a far bettr finsh than using a mallet and grinder
got it in one
think i said i will be buying myself an arch roller so read into that what you will
