Whats my engine code?
Right, i haven't got a clue about engines... And I'm starting learnng about them for future reference so i can fix stuff myself rather than shelling out hundreds of pounds...
Looked on my V5 and it does say APQ, so I'm guessing thats the engine code... But my car is doing a ridiculous amount of MPG, so I'm gunna fix it myself, try and get a donor engine. Can i fit engine parts from other coded engines? For example AEX etc..
Any help is appreciated,
Regards,
Steve.
  • Views 1k
have you thought its petrol prices?
its making a huge difference
Aha, i wish mate! Its using a ridicluous amount, could be crap petrol contributing to my 15mpg(ish) I'm getting. Costing me around 40-50 a week. Been told it could be the piston rings or something like that, could i not just get a donor engine and transfer the bits over?
Does it use oil and smoke out the exhaust? If not, you generally aren't going to gain anything by swapping an entire engine! It might just be running rich due to a sensor or two that need replacing.
Didnt the Lambda Sensor sort it mate?
I'm shocked how much juice its drinking. I think it would be easier to just get the parts for it, when you find out what you need, and replacing them.
APQ Engines are very common anyway so you should be able to pick one up cheaply.
Sweet cheers guys :D
I tried fitting the lambda and mine is rusted on, as is the fanimould cover, gay! So it will need to go to the garage anyway, gunna cost m a fair bit :(
Is anyone local and not busy that can come have a look? Its literally bankrupting me lol!
