Carpark ticket rescue, 6n dash.
I lost a carpark ticket a couple of weeks ago and am going through the process of appealing the ticket. I noticed today that the bloody thing has slipped between the windscreen and dash. My initial attempt at rescuing it failed and it has fallen from sight, does anyone have any idea how I can get to it without removing the dash?
  • Views 795
three ways depending on where it is,
1 if its on drivers side take the clocks out (two screw under the black surround thing then two each side of the clocks) then take out headlight switch and drivers vent and vent pipe to get at it
2 if it on passenger side take out glove box (about 7 screws including the clip for the lock) and remove the vent and pipe on that side
3 if its in the middle take the centre console out, (a screw behind top 2 vents) then 3 abit further back from ashtray (may nee to take centre stick sourround out to get at them, 1 screw in cubby hole pull the gear surround off and theres 2x 10m plastic nuts then wiggle it out) then take the centre piece of centre vent out!
you wouldnt believe how many parking permits i found taking my dash out!!!!
I`ll take option one! Nice one man, had this been a mk2 Golf I`d have had no worries but being new to 6n ways it seemed wise to ask and you`ve come up trumps.
