HELP abs light is on
i was just driving home not fast or anything like that and i look down and the abs light is on how do i fix this?
any help would be appreciated thanks
  • Views 773
anyone?
quick replys
guess one of your abs sensors has failed,or isnt connected
check the abs plugs on the brakes to see if they are ok,also check the terminals haven't bent inside
if alls ok then have the car hooked up to vagcom diagnostics to pinpoint the problem,ie which sensor is duff
